Shift solenoid?
140,000 MILES • 3.5L • V6 • TURBO • 4WD • AUTOMATIC
DOOMBOY987
I have the truck listed above eco boost. I replaced the shift solenoid in it now. When I shift into gear it doesn't go into gear and doesn't give me a code. Just says on the screen "shift to park".
When replacing it I replaced the shift solenoid transmission filter and 8q of fluid.
Jun 24, 2023 at 7:00 AM
  • 110,248 POSTS
When you say, "I shift into gear it doesn't go into gear doesn't give me a code," are you using a scan tool that can read codes from all modules? In other words, are you scanning the can-bus? If not, try that first.
Here is a link that explains how it's done:
Next, the next thing is if there is a transmission line pressure issue. If there isn't enough pressure, it won't go into gear. However, that should set a code.
Let me know if you have scanned the can-bus and we'll go from there. Also, let me know if the linear pressure control solenoid was replaced.
joe
Jun 24, 2023 at 3:12 PM
