Shift solenoid 1-2 2-3
DUWHOP31
  • 151 POSTS
Yes sir. It has to be that the Neutral safety switch or shift linkage is on wrong cause when I first got it started & put it in reverse it went foward. And whn I didnt have the bolt in the bracket u could easily move the gear shift from P to R, N, D
Sunday, July 21st, 2019 AT 7:41 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 50,067 POSTS
So if you remove the cable from the transmission can you move the cable or the gear selector lever?
Tuesday, July 23rd, 2019 AT 2:46 PM
