i was wondering what you ment by shift sensor on your reply ? did you mean the safety switch or the speed sensor ?
Feb 10, 2018 at 1:07 PM
✓Experienced Mechanic
Good morning
It looks like they meant the neutral safety switch.
Feb 10, 2018 at 4:44 PM
FRANKIE052189
MEMBER
where is the neutral safety switch?
Feb 15, 2018 at 4:23 AM
I attached a picture of where the connector is located. follow the wires down to the switch. it is on the transmission where the cable is attached from the shifter.
Sorry for the picture, it is the only one I could find.
Image (Click to enlarge)
Feb 15, 2018 at 5:13 AM
FRANKIE052189
MEMBER
thank you , i was having a hard time trying to find a pic myself and its raining out today so i didnt want to go under the truck which is sitting in a mud puddle now . so should be getting the speed sensor in tomorrow and as long as weather permits i will be putting that in and trying to find the safety switch .
Feb 15, 2018 at 7:36 AM
I hear you. Take a look when you can and we will be here if you need any other help
