Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Cutlass
General
shift relay
1992 OLDSMOBILE CUTLASS
220,000 MILES
TRUSSWIZARD
MEMBER
I need to try and replace the shift relay but i can't locate it on my 92 olds. Please help.
Apr 21, 2013 at 8:53 AM
Experienced Mechanic
there is no shift relay..
What is the issue??
Apr 21, 2013 at 9:01 AM
TRUSSWIZARD
MEMBER
It won't shift past first. The transmission is good. It is something other then the transmission.
Apr 21, 2013 at 9:30 AM
how do you know the trans is fine??
if it does not shift, then either the governor is bad or the throttle cable may be the issue
Apr 21, 2013 at 10:12 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
