Transmission will not shift out of park
204,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
ROB1101
I can't get it to shift out of park.
Oct 15, 2021 at 6:45 AM
SQM
  • 6,383 POSTS
It sounds like you might have a faulty shift interlock solenoid.
That solenoid is what triggers the shift lock to be removed when you depress the brake.
It is located under the shift lever. You will have to remove the console around the shift lever to access it.
Oct 15, 2021 at 7:12 AM
