shift manually
1994 CHEVROLET S-10
160,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
MITCH DEVEREAUX
4l60e in limp mode second and drive, no low or overdrive. is it possible to disconnect comp. and shift manually?
May 20, 2021 at 5:04 PM
Good morning,
No, it cannot be disconnected since it is controlled by the ECM.
You most likely have a valve body issue in the transmission. I would start by changing the fluid and filter and see if there is any metal in the bottom of the pan.
May 20, 2021 at 6:46 PM
