Shift lock
131,281 MILES • V6 • 2WD • AUTOMATIC
MAMA2013
My gear shift is locked in first gear. I just had the shifter assembly replaced so I know that is not the problem. What else can cause that and how do you fix it?
Nov 18, 2018 at 6:13 AM
  • 55,737 POSTS
It sounds like the shifter cable has come apart not letting you move the shifter but to be sure let's disconnect the cable from the shifter. Here are guides to help us get started below.
Cheers, Ken
Nov 19, 2018 at 9:48 AM
MAMA2013
Thanks, I will try this and see.
Nov 20, 2018 at 10:30 AM
  • 55,737 POSTS
Please let us know what you find. :)
Nov 23, 2018 at 3:07 AM
