When I try to change gear mode it does not shift?
79,500 MILES • 1.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
MCHUTTY
What’s happening to my car if suddenly, while driving, the gears don’t engage. The engine runs, but when i try to change gear mode it doesn’t shift.
Nov 30, 2024 at 11:05 AM
  • 55,540 POSTS
So does the car move and not shift or does the car not move? Anytime you have a transmission problem it is best to check the fluid level and condition. Here is a guide to help with the instructions for your car in the images below.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Also, can I ask if the reverse lights come on? This can help test the gear range sensor, we should run the codes as well.
This car has the CVT transmission which has a history of failure. Let me know if the fluid is dark and burnt smelling. Checking this fluid is much like the old standard transmission with a drain plug in the side of the case which is what the level should be. You might want to try a fluid change as well.
Use Honda HCF-2.
NOTE: Using the wrong type of fluid will damage the transmission.
Dec 1, 2024 at 4:06 AM
