Shaking while braking from 45-55 MPH?
250,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
JACOB MARINO
  • 45 POSTS
My truck shakes when I brake from high speeds. Specifically, 45-55 MPH but less violent shakes at other speeds. It doesn't happen while accelerating, so I ruled imbalanced/misaligned tires out. My rears are squeaking at me I believe it is just the brake pads needing replaced (correct me if I am wrong about that please) but also my brake pedal pulses when I push the brakes. Not all the time, but especially coming to a stop at slow speeds. Warped rotors?
May 29, 2023 at 8:01 PM
  • 55,721 POSTS
Yep, you are probably correct though tie rod ends can cause this as well.
Here is a guide to help you see what's going on:
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
and
https://www.2carpros.com/articles/a-deep-dive-into-resolving-shaking-steering-wheel-when-braking
Here is how to change the brake rotors and pads out in the video below:
https://youtu.be/9pwFodKAl5A
Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 30, 2023 at 10:59 AM
JACOB MARINO
  • 45 POSTS
So, I drove it around today without changing anything out yet and the noise stopped. I can't hear it anymore. Is it possible that the speaking was just thin rust buildup scraping away? It has been raining over here quite often recently. As for the shaking, I will check out the rotors and tie rods.
May 30, 2023 at 11:07 AM
  • 55,721 POSTS
Yes, this is very possible. The rust could be getting cleaned off of the brake rotors which is common. Use 2CarPros anytime, we are here to help. Please tell a friend.
Jun 1, 2023 at 7:44 AM
