Shaking low rpm
300,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
DEV777
  • 10 POSTS
I have the XLT model. It has had this problem since i got it (about 8,000 miles ago). Just to give you a good idea about what is happening, I will give an example. Let's say I am driving on a level road going about thirty five mph and I slowly accelerate without any problem to forty mph. Once i reach forty mph, my truck shifts to fourth gear. i maintain this speed with extreme minimal throttle. If i try to accelerate just the slightest bit, the truck begins to shake. If I go ahead and give it about half throttle, it will downshift and smoothly accelerate without shaking. However, if I do not give it more throttle or if I begin up a small incline/grade, my truck will shake madly. In other words, if I drive at forty mph, with just the right throttle pressure, my truck will shake constantly.
Oct 26, 2017 at 9:21 AM
  • 110,248 POSTS
I dealt with this same problem recently. The check engine was on, but there was no indication of an engine problem such as a misfire. Upon further investigation, I found the torque convert clutch (TCC) was not functioning properly causing the vehicle to shake. Basically, it felt like an engine misfire problem. It only did it around the same speed under the same conditions you mentioned. The customer had to replace the aforementioned item and the problem was solved. If you have a scanner that can read transmission codes, check that first.
Oct 26, 2017 at 11:39 AM
DEV777
  • 10 POSTS
Okay, thank you i will try to get it scanned tomorrow and see if any thing comes up.
Oct 26, 2017 at 12:04 PM
CARADIODOC
  • 34,414 POSTS
The best suspect is the transmission's torque converter clutch. The clue is the forty mph.
The torque converter is the fluid coupling between the engine and the transmission that allows the engine to remain running when the vehicle is standing still, in gear. It starts to become efficient at around 1000 rpm, but that slippage always exists while you are driving. The lock-up clutch eliminates that slippage to achieve better fuel mileage, similar to what a manual transmission's clutch would do.
That lock-up clutch cannot be allowed to engage at lower speeds, and when it does engage, it has to do so gradually to avoid causing a harsh clunk. Most lock-up clutches begin to engage gradually between thirty five and forty five mph. It is cycled on and off very rapidly to modulate its engagement, but there are special additives in the transmission fluid to allow it to slip at first. The most common cause of this shudder is using the wrong transmission fluid. Without the needed additives, the clutch engages too hard, then engine torque causes it to break free, then it locks up again, very rapidly.
To prove if this is the cause, when the shudder occurs, hold the accelerator pedal perfectly steady, then lightly tap the brake pedal with your left foot. That will cause the lock-up clutch to disengage for a few seconds, (in preparation for coming to a stop), then the shudder will occur again when it engages. If you have a tachometer on the dash, if you tap the brake pedal at higher speeds, you will see engine speed increase about 200 rpm. That is due to the lock-up clutch releasing. It also releases at wide-open-throttle, (for more torque), and it will not lock up until the engine is warmed up. That is to insure the transmission fluid is warm enough to flow easily to the cooler.
Oct 27, 2017 at 7:15 AM (Merged)
DEV777
  • 10 POSTS
So while holding the gas in the shaky spot tap breaks and see if it smooths out for a second? To see if it is the torque converter.
CARADIODOC
  • 34,414 POSTS
Yes. If the shudder stops, have a standard fluid and filter change performed, and be sure they use the correct fluid listed for your vehicle.
DEV777
  • 10 POSTS
I will give it a try. i did do the transmission gasket and filter and did ask O'Riley's the best transmission fluid for it and they pointed it out. i also changed the coil, spark plugs and wires.
CARADIODOC
  • 34,414 POSTS
No need to replace the filter again so soon. To insure you get the right fluid, you might want to buy it from the dealer's parts department.
DEV777
  • 10 POSTS
Okay, i am going to drive it and see what happens ill be back on tonight or tomorrow with updates. thank you.
DEV777
  • 10 POSTS
Okay, I believe you are right. when I was driving it started to shake I tapped the break it smoothed out for a second, made a loud clunk and then started to shake again.
  • 55,737 POSTS
You will need to remove the transmission to swap out the torque converter. Here is a guide that give you an idea of what you are in for the service and the removal:
and
https://www.2carpros.com/articles/transmission-replacement-removal-manual
Please let us know what happens so it will help others.
Cheers, Ken
DEV777
  • 10 POSTS
Will do. thank you for the replies plan on taking it on Monday.
Oct 27, 2017 at 7:34 AM
  • 110,248 POSTS
Keep us updated. I am interested to see if is the same problem I dealt with. If so, we will most likely see more of the same and it will be helpful to others.
Oct 27, 2017 at 12:58 PM
