Start truck up rpm's go up to 2000 rpm's, then drop down to 1500 rpm's and then goes down to 900 rpm's. when put into reverse and drive I have it set to ten degrees BTDC, then it goes up to 18 to 25 with spout connector in, are the rpm's supposed to be in that range?
Mar 2, 2017 at 8:12 AM
