shaking car when accelerating and the check engine light turned on?
80,000 MILES • TURBO • 4WD • AUTOMATIC
CADEHARRIS11
Whenever i start my car and give it gas to drive somewhere, the car starts shaking when i push gas, check engine light came on around the same time as well.
Jun 20, 2024 at 7:37 AM
STEVE W.
  • 15,411 POSTS
Well, the first thing to do would be to scan it to see what codes are stored in the system. I also wouldn't drive it until it is repaired, shaking and check engine light generally means it is misfiring and that can do a lot more damage than other problems. The vehicle should still be under the 10-year 100,000-mile warranty as well so it should be covered unless it was a salvaged vehicle. I would call the local dealer and give them the information about the car. Then they should repair it.
Jun 20, 2024 at 11:25 AM
