Shaking at highway speed
102,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
F150ECOBOOST
Bought this car used and it has been shaking since I bought it. Took it back to dealer, they balanced the tires and checked the car over and could not find anything wrong. It did not fix the issue.
I've replaced the tires, all the brakes and rotors, rear shocks, all the wheel bearings, both CV axles, and the tires. Even had the rear brake caliper replaced. Nothing has worked.
I've had the tires balanced and rotated a few times and nothing has changed. At about 70 MPH the car vibrates and shakes.
Then I noticed the tire shop sold me 215/65R17 tires. The sticker on the door of the car says 245/45R19. Could this be my issue?
Jun 4, 2022 at 9:47 AM
Just having the wrong tire size is not going to cause a vibration.
The way to fix this is use a vibration analyzer. The dealer should have one and I would call the manager and tell them they need to use the tool if they have one.
If they do not have one, then they need to pay for another dealer to use theirs.
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
If none of this works, then we need to find out if the axles are bent.
Start with finding out if you feel the vibration in the seat or in the steering wheel?
If it is in the seat, start with measuring the rear hub runout and this will tell us if we have a bent hub/axle.
If it is in the steering wheel, then the front is the issue.
Lastly, they will have to check for vertical runout on the axle hub to see if we have a housing issue as well allowing up and down movement.
However, all of this will be clear if we have a vibration analyzer. That will tell us what type of component is causing the vibration because this could be a driver shaft as well.
Let's start with this and go from there. Thanks
Jun 4, 2022 at 11:23 AM
F150ECOBOOST
This is a great place to start, thank you so much. I'll get this vibration analysis and report back. Thanks again!
Jun 4, 2022 at 11:05 PM
Sounds great. Thanks.
If they are not sure how to read it, have them right down the following info and I can help figure out the cause.
All this info is when the vibration is there-
Hertz reading
RPM
Speed
Tire size
axle ratio
With that info, I am sure we can narrow this down.
Thanks
Jun 5, 2022 at 2:28 AM
