Shaking and burning smell
300,000 MILES • 6 CYL • 2WD • AUTOMATIC
DIMINSONSAM
Couple of days ago I start my car and it's shaking badly and doesn't have the amount of power. Like I have to go into higher rpm's to get up to speed, and if you idle for a minute or drive a bit you can smell something burning. I first checked plug wires making sure they were in good condition and not against anything hot, then I looked for foaming in the oil, then I looked for hoses that are worn, bubbled, kinked and I couldn't find anything. Checked my transmission fluid that was fine should also mention. It doesn't always do it when I start the car. Yesterday it was fine for a bit then it started again.
Jul 1, 2020 at 9:48 PM
Good morning,
Are there any codes set? It sounds like the engine has a misfire and is making the engine run rough.
It could be plugs, wires, coils, or modules.
It could also be a compression issue with the cylinder that is missing. I would check the compression.
The smell most likely is from the exhaust from the misfire.
Jul 1, 2020 at 10:49 PM
