Car shakes when transmission is shifted into reverse
140,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
MICHAEL HEIL HEIL
When starting the car, everything works fine, after putting it in reverse, the car seems to shake violently, in drive throughs and stop lights this happens too, where it will just shake. I need help.
Sep 26, 2020 at 7:00 PM
SQM
  • 6,383 POSTS
So just to clarify, the car shake only while you at a stop and while you put in to reverse?
Does it drive normal when you drive down the road?
Is your check engine light on?
If so you need to get it scanned. That needs to be the first step, as it can help point us to the right direction of getting this resolved.
https://www.youtube.com/watch?v=b2IJGfImVvw
https://youtu.be/vMwTzURWXmk
Let me know of any questions.
Jul 17, 2021 at 5:37 AM
