Shaking while driving speeds of 25 to about 40 MPH
150,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
RICKYSH11
  • 75 POSTS
Hello, I am experiencing shaking while driving speeds of 25 to about 40 mph. The issue is not present at a cold start but after driving for quite time it begins to occur. I've checked tires for an abnormalities and didn't find any issues. I also checked for any loose bolts on the suspension. This issue only occurs while the vehicle is moving accelerating and braking alike.
Jun 15, 2021 at 11:50 AM
  • 110,248 POSTS
Does the shaking get worse when you apply the brakes? Also, do you feel it more in the steering wheel or the seat/floor? Has tire balance been checked?
Also, is the check engine light staying on when the engine is running?
Jun 16, 2021 at 3:23 PM
RICKYSH11
  • 75 POSTS
Hello, thanks for your reply. The shaking continues the same throughout braking but when the vehicle comes to about 10 MPH the shaking stops all together. It's very minimal in the steering wheel and some shaking can be felt in the seat and floor. The check engine light is on and stays on. The only code it's been showing is for the fan speed sensor. The traction control light is illuminated as well, and I am only able to use 2 wheel drive since it has been on. The balance hasn't been checked yet.
Jun 17, 2021 at 12:13 AM
  • 110,248 POSTS
It sounds like you have a couple of different things happening. As far as the traction control and 4wd, that is likely related to a wheel speed sensor. As far as the vibration, have you had the tire balance checked? It isn't uncommon for a vibration to start and then go away at a specific speed if there is a balance issue.
Also, a bad universal joint could be causing it as well. Take a look through this link:
https://www.2carpros.com/articles/how-u-joints-work
Jun 17, 2021 at 2:02 PM
RICKYSH11
  • 75 POSTS
Thanks again! I had the tires checked and I was told that the two in front would need to be replaced due to wear on the outer tread. I had suspected the ujoint being an issue. I have been hearing the described squeaking from the link you provided. I plan to check it out this weekend.
Jun 18, 2021 at 12:40 PM
  • 110,248 POSTS
You are very welcome. Let me know if there is anything I can do to help.
If you have a chance, let me know what is found.
Jun 18, 2021 at 2:00 PM
RICKYSH11
  • 75 POSTS
Hey Joe, it turned out to be the U-joint on the front shaft. I change the front and the rear one out and now it's going pretty good. No more noise and vibrations. I also found that 2 heat shields were completely unmounted and just moving freely as I operated the vehicle. So I took of that as well.
Jul 21, 2021 at 2:22 AM
  • 110,248 POSTS
Thanks for the update. I'm glad to hear you got it taken care of. Also, chances are it will help others with similar problems.
Please feel free to come back anytime in the future if you have questions or need help. You are always welcome here.
Jul 21, 2021 at 1:37 PM
