Shaking when turning or at high speeds
190,000 MILES • 2.2L • 2WD • AUTOMATIC
BRADEN MCCANN
When I am driving at high speeds or taking a right turn my car will shake/wobble. I have had the wheels balanced, the tires are new, and have been insured that tire bearing are in order. Just wanted to know if I should be concerned.
Oct 17, 2017 at 11:54 AM
  • 31,937 POSTS
If there is a vibration there is a problem. i would be getting the tire and rim re checked for run out. ensure that the wheel bearing is okay, there should be no sideways movement in the bearing at all and no roughness when spun, and steering and suspension components are sound and serviceable. if you hear or feel a noise there will be a problem. also, check drive shafts for excessive noise and slop in the CV's.
Oct 17, 2017 at 4:27 PM
