2004 Saturn Ion Ballpark price of fixing a caster split
KAEJORR1977
Shakes or Wobbles problem
2004 Saturn Ion 4 cyl Front Wheel Drive Automatic 103k+ miles
I went to get a realignment on my car and they told me that there was a caster split. I was wondering how much the general going rate of fixing something like that would be, as they did not offer the service at their shop.
Feb 24, 2010 at 8:32 AM
SATURNTECH9
  • 30,869 POSTS
[quote:a35fbfcc7d="kaejorr1977"]Shakes or Wobbles problem
I went to get a realignment on my car and they told me that there was a caster split. I was wondering how much the general going rate of fixing something like that would be, as they did not offer the service at their shop.[/quote:a35fbfcc7d]
if ur talking about sloting the strut towers so u can adjuster the caster then for both sides to slot them it would be 1.2hrs times what ever shop labor rate is which is usually 80-100 per hr.then u have to get it aligned.but if ur talking about something else let me know.because i havent heard of a caster part only as a adjustment.
Feb 24, 2010 at 9:50 AM
KAEJORR1977
He said there was an issue where it probably hit a curb or something and that it would always be off some until it was fixed. At this point, I know that my wife hit a curb once pretty hard, but I am not sure if it is the struts or something else that needs repairing. When I apply the brakes it shakes pretty significantly and it is causing one of my tires to be worn on the inside wall.
Feb 25, 2010 at 2:56 AM
SATURNTECH9
  • 30,869 POSTS
[quote:acf638446d="kaejorr1977"]He said there was an issue where it probably hit a curb or something and that it would always be off some until it was fixed. At this point, I know that my wife hit a curb once pretty hard, but I am not sure if it is the struts or something else that needs repairing. When I apply the brakes it shakes pretty significantly and it is causing one of my tires to be worn on the inside wall.[/quote:acf638446d]
when u hit a curb the lower control arm usually bends but without seeing it or knowing what is bent i really cant give u a price on how much it would cost to fix it.usually when u brake and it shakes its usually brake related like warped front rotors or something like that let me know.
Feb 25, 2010 at 3:28 AM
KAEJORR1977
Well the brake pads and rotors are fairly new still, and when I got the alignment done the shaking lessened considerably, to where it was almost normal. I appreciate your answers, I should probably just do it the hard way and have someone look at it and price it out.
Feb 25, 2010 at 4:47 AM
