Shaking
199,999 MILES • 4.7L • V8 • 4WD • AUTOMATIC
LDMATHIS
  • 5 POSTS
Hi, my car will shake randomly. It does not matter what speed and its random. i went almost ninety miles yesterday with no shake. but on the way back it shook. Sometimes it will shake, sometimes it will not. more time than not it does though. it gets to shaking so bad i have to pull over. i already got one of my tires balance because a weight was off, but it was not it. what could cause it to shake at random?
May 8, 2017 at 1:30 AM
HMAC300
  • 48,601 POSTS
have the front end checked it can be a wheel bearing, or something in front end causing it like a ball joint especially after hitting a bump.
May 8, 2017 at 2:40 AM
LDMATHIS
  • 5 POSTS
Wouldn't a ball joint or something like it do it all the time?
May 8, 2017 at 3:09 AM
HMAC300
  • 48,601 POSTS
not really they mostly do it after hitting a bump and it depends on how worn the joint is and whether or not it is greaseable. Or an idler arm.
May 8, 2017 at 5:03 AM
LDMATHIS
  • 5 POSTS
Would a back sway bar do it?
May 8, 2017 at 5:15 AM
LDMATHIS
  • 5 POSTS
Definitely cant. but, how do i check to see if my steering damper is out?
May 8, 2017 at 6:33 AM
HMAC300
  • 48,601 POSTS
sway bar can do it yes so can a misfire in the engine. usually a damper leaks oil is a way to check . but if this is a stock car and no big tires on it then I doubt its that.
May 8, 2017 at 8:03 AM
  • 55,748 POSTS
Raise the front end in the air, then grasp each wheel at move it back and forth to check for anything loose. This will show you the part that is worn out, Probably an idler arm.
Here is a guide that might help as well.
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
May 8, 2017 at 9:06 AM
LDMATHIS
  • 5 POSTS
We checked all the tires again and again. We finally found that my front tire has a broken belt and is in pretty bad shape. We thought it was something major because it didn't do it all the time. But, whenever i took it to walmart they balanced it, so now it makes sense that the reason it didnt shake on the way down there was because it took a while for the tire to get unbalanced all over again, creating the problem again. Thank you for all of your help.
May 8, 2017 at 12:38 PM
  • 55,748 POSTS
Sometime the tire is broken inside and it only shows up with the weight of the car on it.
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers, Ken
May 9, 2017 at 4:15 AM
