Front end shaking while driving and when stopped
2007 NISSAN ALTIMA
98,000 MILES • 2.3L • 4WD • AUTOMATIC
POWELLDV4
while driving car over the weekend once got up to seventy mph my whole front end started shaking and when i came to a stop it shook as well. i do not know why
Mar 20, 2018 at 6:06 AM
  • 31,937 POSTS
is the engine running smoothly? If the front is shaking with out moving you may have a chronic misfire in the engine. Did the shake stop after a short time with the engine still running? if so look for very worn suspension components, it is a bit hard to understand the exact problem, so any more information will be a great help as well.
Mar 20, 2018 at 10:56 PM
POWELLDV4
Thank you for responding back very helpful. Yes, the engine is running smoothly i took it to the mechanic and he said he could not find anything after it did it the first time. i parked the car and did not drive it until two days later. it has not done it again.
Mar 21, 2018 at 4:49 AM
POWELLDV4
The check engine light also started flashing in and out as well. should i take it to another mechanic and get it looked at?
Mar 21, 2018 at 5:14 AM
  • 31,937 POSTS
Yes, if the check light has been on there will be a stored code. get this scan done and post the code for further assistance.
Mar 21, 2018 at 9:22 AM
