While driving over forty five MPH car shakes
175,000 MILES • 4 CYL • 2WD • MANUAL
KYLIE-1218
When i go under 45 mph the car doesn’t shake but one i get over 45 and turn even the slightest bit to the right (even to straighten up on straight a ways) the car will shake rapidly.
May 9, 2020 at 5:12 PM
Good morning.
You need to have the front end check for any worn parts. It could be tires, axle shaft or loose steering components.
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
https://www.2carpros.com/articles/replace-cv-axle
I would get it checked ASAP as you do not want to have a failure and loss of steering.
May 9, 2020 at 8:53 PM
