it shakes real bad when I accelerate, but when I let off the gas it is normal. it vibrates when I'm at a red light
Dec 29, 2015 at 1:02 AM
HMAC300
✓Experienced Mechanic
scan for codes it may be a misfire in engine
Dec 29, 2015 at 1:42 AM
DEANNA77
MEMBER
I was hoping you could be more specific before I get codes. that's kind of my point in asking.
Dec 29, 2015 at 4:34 AM
HMAC300
unfortunately with todays cars from your question is what sounds like a misfire. auto parts can do for free to find out exactly if a code. the only other thing you can do is to check for vacuum lines off/broken/cracked etc. Or maybe something obvious by running car and seeing spark jump from a wire off maybe or a broken wire.
