Shakes and shutters
2004 CHEVROLET MALIBU
172,000 MILES • 2.2L • 4 CYL
MIKE DAYE
Okay, I have actually pin pointed the problem a little bit. when I am going right on anything while it is fine, but when I turn left and give it gas is shutters really bad like the on the driver's side the CV joints look in good condition. the boots are good. checked the rotor seems good as well. could a unbalanced tire do this ?
Apr 15, 2017 at 9:18 PM
HMAC300
  • 48,601 POSTS
yes, either unbalanced or a belt broke inside it. switch to back and see if it makes a difference then check wheel bearing.
Apr 16, 2017 at 1:36 AM
MIKE DAYE
Okay, thank you.
Apr 16, 2017 at 3:50 AM
  • 55,412 POSTS
Best, Ken
Apr 18, 2017 at 5:10 AM
