SEE IF THE INFO IN THIS LINK HELPS
https://www.2carpros.com/questions/2005-ford-escape-every-day-crank-suv-high-idle-usually-after-30-minutes
IN THAT SITUATION, THE CHECK ENGINE LIGHT WAS NOT ON,
IF YOURS IS ON YOU NEED TO SCAN IT FOR CODES FIRST, BEFORE YOU START BUYING STUFF. YOU MAY HAVE A DIFFERENT PROBLEM THAT THE COMPUTER DETECTED.
MOST POPULAR PARTS STORES WILL DO THIS FOR FREE. IF YOU ARE DEAD IN THE WATER, YOU CAN BUY A CHEAP SCANNER FOR MAYBE $50 ON UP. (PROBABLY IS CHEAPER THAN TOWING IT SOMEWHERE). THIS IS A TOOL THAT YOU OR YOUR PALS CAN USE FOR FUTURE PROBLEMS.
RETURN HERE WITH THE CODE #s, IF ANY, I'LL ATTEMPT TO FURTHER AID YOU.
I'M HOPING THE FIRST SITUATION IS ALL IT IS, CLEANING IT MAY FIX YOU RIGHT UP
THE MEDIC
Dec 26, 2015 at 9:23 AM
