severe oil leakag that started at once
175,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
JOHNCR
Thanks, last night described vehicle, cut off while driving. Under hood saw much oil low on engine, oil check showed no oil, though when checked days earlier was full.
It appears to be leaking from an round part, that has wires, located at front of engine, under heads. and when started this morning steady flow of oil leakage?
I don't know what this part is? Sticks out from engine approx. 3 inched with 2-3 wires at tip of part.
Aug 1, 2015 at 12:11 AM
CARADIODOC
  • 34,415 POSTS
It sounds like you're describing the oil pressure sending unit. It's not uncommon for them to start leaking. Any auto parts store will have a replacement. If you can remove the old one first, take it along to match it to the new one.
Aug 1, 2015 at 3:42 PM
