several oxygen sensor codes?
185,000 MILES • 6 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Any reason you can elaborate on why all these codes have all popped in together?
P013A
P013C
P013E
P014A
P0158
P2273
P0138
P2271
Please let me know.
Dec 22, 2023 at 12:12 AM
  • 55,710 POSTS
Here are what the codes mean:
P013A - O2 Sensor Slow Response - Rich to Lean (Bank 1 Sensor 2):
P013C - O2 Sensor Slow Response - Rich to Lean (Bank 2 Sensor 2):
P013E - Delayed Response of Downstream O2 Sensor (Bank 1 Sensor 2) to Lean Condition:
P014A - O2 Sensor Delayed Response - Lean to Rich (Bank 1 Sensor 2):
P0158 - O2 Sensor Circuit High Voltage (Bank 2 Sensor 2):
P2273 - O2 Sensor Signal Stuck Rich (Bank 2 Sensor 2):
P0138 - O2 Sensor Circuit High Voltage (Bank 1 Sensor 2):
P2271 - O2 Sensor Signal Stuck Rich (Bank 1 Sensor 2):
https://www.2carpros.com/articles/how-to-replace-an-automotive-engine-computer-pcm-ecm-ecu-a-comprehensive-step-by-step-guide
Here is how to change the PCM out in case you need it, you can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Please upload pictures or videos of the problem so we can see what's going on.
Dec 22, 2023 at 4:21 AM
