Multiple engine codes
182,000 MILES
DIVIDES
  • 903 POSTS
Do these codes lead you to any type of suspicion about where the problem is in general? My friend has it, and this is what it's showing.
P0191
P0300
P0420
P0442
P0113
P2228
P0496
Dec 29, 2021 at 11:36 PM
  • 110,248 POSTS
The codes are all over the place. One is a small evap leak, one is a catalytic converter issue, barometric pressure sensor, fuel rail pressure sensor, and so on.
If I had to guess, I suspect there is a wiring issue (5v reference signal) to the fuel pressure sensor and the barometric pressure sensor.
Is the vehicle running normally or are there specific conditions?
Dec 30, 2021 at 2:30 PM
