Sunroof inoperable, same for driver side set, traction light on, no throttle response
64,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
DIVIDES
  • 903 POSTS
Sunroof inoperable, same for driver side set, traction light on, no throttle response, starts and can drive it around the block, when parked no response. Sometimes the engine revs on its own when in park. Some water on floors from sunroof issue. Tried to activate the roof but i only heard a click from the motor. No clicks heard from the seat.
The first scan is in the first picture, the second motor scan in second picture and the third one left me with one code. I have a feeling it's the pedal sensor.
Voltage and battery Re where they should be. Also scanned seats and other things i can scan. Also, the radio works but no sound.
May 3, 2022 at 5:51 AM
DIVIDES
  • 903 POSTS
I am just afraid they all related cause if the water that yot in. Maybe the sunroof stopped working and then when water came in messed up the seat and the gas pedal sensor. Can you just tell me where the ecu is? I'll send it for repair, if they find nothing, they won't charge me anything.
May 3, 2022 at 11:30 AM
  • 55,554 POSTS
This sounds like the front SAM control module is out which is common, here is the location so you can get it checked out. I have also included the ECM location as well. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
May 4, 2022 at 9:44 AM
DIVIDES
  • 903 POSTS
Which if these is the SAM module? How do i test it? And does it need programming? I don't see any diagrams.
May 4, 2022 at 9:54 AM
DIVIDES
  • 903 POSTS
I found it, very tight space, any instructions on how to remove it? I think i see 4 torx bolts that hold it down, just want to make sure.
May 4, 2022 at 11:50 PM
DIVIDES
  • 903 POSTS
Removed it based on videos. Some guy also said SAM for the other one that is by the battery, not sure why. First picture is mine.
May 5, 2022 at 1:19 AM
  • 55,554 POSTS
Yep that's it, here is the text on how to replace it it what it does,
N10/1 Front SAM control unit with fuse and relay module
Location
The front SAM control unit with fuse and relay module is located at the left in the engine compartment.
Task
Two microprocessors are installed in the front SAM control unit, one for control of basic functions such as, e.g. the exterior lights (ABL), and the second for control of the central gateway functions. Both processors communicate internally with each other over the interior CAN (CAN B) and they can undergo separate diagnosis. The front SAM control unit also has a 3D acceleration sensor integrated into it which is used to detect any crash events.
For model 204.9 a speedy journey over uneven roads can cause significant vibrations which in turn may induce the 3D- acceleration sensor to be actuated. These are entered into an event memory. When mounting, make sure that the front SAM control unit is securely seated.
The processor is responsible for the following tasks for controlling the central gateway functions:
- Central gateway (CAN interface)
- Data container
- System diagnosis
- Global variant coding
- Monitoring CAN bus idle
The processor is responsible for the following tasks for controlling the basic functions:
- Interior CAN and LIN interface
- Reading in of sensors, pickups and signals
- Evaluation of input factors
- Controlling functions
- Actuation of components
The fuse and relay module of the front SAM control unit supplies various systems and control units with power through limit switches to match the function sequence.
The following tasks are the responsibility of the fuse and relay module:
- Voltage supply to components
- Power supply and relay switching
- Switching consumers using relays
Detailed information is available in the "Fuse and relay box, asbuilt configuration" function description.
The processor for controlling the central gateway functions also acts as an interface between the following data bus systems:
- Interior CAN
- Diagnostic CAN (CAN D)
- Chassis CAN (CAN E)
- Front end CAN (CAN G)
Data container
The data container represents a nonvolatile, mobile data memory and is managed by the processor for controlling the central gateway functions.
Benefits:
During production, vehicle-specific, test location-specific and control unit-specific data are stored in the data container (e.g. production number, test status, partial tests not completed). These data can be used in the subsequent tests for test sequence control. The total size of the data memory is 128 bytes.
System diagnosis
The system diagnosis is integrated as a software module in the processor for controlling central gateway functions.
For off-board diagnosis, the following on-board functions are realized by the processor responsible for controlling the central gateway functions:
- CAN line diagnosis
- CAN SPECIFIED/ACTUAL configuration
- Data logger for telediagnosis
The processor responsible for controlling the central gateway functions forwards global information such as model series and national version over the various CAN buses to the networked control units. The control units perform part of their configuration process to match this information.
The monitoring of the CAN bus idle enables control units to be determined, which keep the CAN bus active at what otherwise is expected to be a CAN bus idle period.
This information is filed in a nonvolatile memory. This in turn serves to ensure that even when the on-board electrical system battery (G1) has been discharged and following a reset of the networked control units, it is still possible to determine whether the discharging of the on-board electrical system battery was caused by the network or by an individual CAN user.
The processor for controlling the basic functions also acts as an interface between the following data bus systems:
- Instrument panel LIN (LIN 1)
- Wiper/inside rearview mirror LIN (LIN 2)
- Interior CAN
The input factors are read in via the following connections:
- Direct line
- CAN
Direct line
The processor for actuating the base functions reads in the signals of the following components over direct lines:
- Refrigerant pressure sensor (B12)
- Outside temperature sensor (B14)
- Interior temperature sensor with integrated fan (N70/3b1) (without code (414) Electric glass tilting/sliding roof)
- Exterior lights switch (S1) (as of 1.6.10)
- Right front brake wear sensor (S10/2)
- Right rear brake wear sensor (S10/4)
- Brake fluid level switch (S11)
- Parking brake indicator switch (S12)
- Backup lamp switch (S16/2) (for transmission 711, 716)
- Coolant level switch (S41)
- Windshield washer system fluid level switch (S42)
- With code (B03) ECO Start-stop function
- Additional battery (G1/7) (Charge level)
- Right engine hood contact switch (S62/42) (without code (U60) Pedestrian protection)
The processor for controlling the basic functions reads in the signals from the following components over an instrument panel LIN:
- Upper control panel control unit (N72/1)
- Exterior lights switch (up to 31.5.10)
- Instrument panel switch group (S6/1)
The processor responsible for controlling the basic functions reads in the signals from the following components over a wiper/inside rearview mirror LIN:
- Inside rearview mirror (A67) (with code (249) Automatically dimming inside rearview mirror and outside mirror (driver))
- Garage door opener (A67n2) (with code (232) Garage door opener with frequency 284-390 MHz)
- Light sensor (B38/1) (model 204.0/2 up to 28.2.11, model 204.9 without code (345) Rain sensor)
- Rain/light sensor (B38/2) (model 204.0/2 up to 28.2.11, model 204.9 with code (345) Rain sensor, model 204.0/2 as of 1.3.11, model 204.3)
- Interior temperature sensor with integrated fan (N70b1) (with code (414) Electric glass tilting/sliding roof)
The communication with the processor responsible for controlling the central gateway functions can also send the data read in by the processor responsible for controlling the basic functions to control units that are not connected to the interior CAN.
CAN
The processor responsible for controlling the basic functions reads in function-relevant data over the interior CAN.
Information from control units that are not connected to the interior CAN are sent by the processor responsible for controlling the central gateway functions over the interior CAN. This can be information from control units, which are connected to one of the following CANs:
- Chassis CAN
- Front end CAN
- Diagnostic CAN
The functions that use these signals are described in the individual function descriptions (see block diagram or function schematic).
The input factors are evaluated by the processor responsible for controlling the basic functions whereupon the corresponding components are then actuated.
The processor responsible for controlling the basic functions manages the following functions:
- ABL
- Interior illumination (IBL)
- Wiper system (WSA)
- Windshield washer heater (with code (875) Heated windscreen washing system)
- Headlamp cleaning system (with code (600) Headlamp cleaning system)
- Central locking (CL) for rear doors, crash opening (up to 30.11.09)
- Rain closing of tilting/sliding roof (SHD) (with code (414) Power glass tilting/sliding sunroof and code (345) rain sensor)
- Decouple on-board electrical system battery and activate additional battery (with code (B03) ECO start/stop function)
The actuation of the components takes place via the following connections:
- Direct line
Direct line
The following components are actuated over direct lines by the processor responsible for controlling the basic functions:
- A/C compressor regulation valve (A9y1) (without code (B09) A/C compressor with magnetic clutch)
- A/C compressor regulation valve (A9/7y1) (with code (B09) A/C compressor with magnetic clutch)
- A/C compressor magnetic clutch (A9/7y2) (with code (B09) A/C compressor with magnetic clutch)]
- Left front lamp unit (E1)
- Right front lamp unit (E2)
- As of 1.12.09 with code (621) Intelligent light system (left-hand traffic) or code (622) Intelligent light system (right -hand traffic) and without code (498) Japan version
- Left daytime running lights headlamp (E1/3)
- Right daytime running lights headlamp (E2/3)
- Up to 30.11.09 and as of 1.12.09 without code (621) Intelligent light system (left-hand traffic) and without code (622) Intelligent light system (right -hand traffic) or with code (498) Japan version
- Left front fog lamp (E5/1)
- Right front fog lamp (E5/2)
- With code (494) Canada version or code (460) USA version
- Left front side marker lamp (E6/1)
- Right front side marker lamp (E6/2)
- With code (954) Avantgarde or code (955) Elegance
- Left center vent symbol illumination (E10/1)
- Left front side air vent symbol illumination (E10/2)
- Right front side vent symbol illumination (E10/3)
- Right center air vent symbol illumination (E10/4)
- Rear vent symbol illumination (E10/5)
- Right front footwell lamp (E17/15)
- Left front footwell lamp (E17/16)
- Glove compartment lamp (E13/1) (switched via the glove compartment lamp switch (S17/9))
- As of 1.6.12 for model 204.9:
- Driver instrument panel ambiance illumination (E43/7)
- Front passenger instrument panel ambiance illumination (E43/8)
- Left fanfare horn (H2)
- Right fanfare horn (H2/1)
- Decoupling relay (F32k1)
- Additional battery relay (K57/2)
- Windshield washer system pump (M5/1)
- With code (600) Headlamp cleaning system
- Headlamp cleaning system pump (M5/2)
- Coolant circulation pump (M13/5)
- Spray nozzle heater (R2/1)
- With code (875) heated windshield washer system:
- Spray nozzle hose heater (R2/11)
- With code (301) Ashtray package/smoker package:
- Ashtray illumination (R3e1)
- With engine 272 with code (494) USA version:
- Purging switchover valve (Y58/1)
- With engine 272 without code (494) USA version:
- Activated charcoal canister shutoff valve (Y58/4)
The following components are actuated via the instrument panel LIN:
- Exterior lights switch (up to 31.5.10) (Function feedback)
- Instrument panel switch group (function feedback)
- Upper control panel control unit (function feedback)
The following components are actuated via the wiper LIN:
- Wiper motor (M6/1)
May 5, 2022 at 2:52 AM
DIVIDES
  • 903 POSTS
All of that is controlled by this box. Geez... what does it have in it other than fuses? This is amazing. I ordered one with same part number.
May 7, 2022 at 2:40 AM
  • 55,554 POSTS
I know, right? They have an integrated circuit board inside. Let me know how it goes.
May 7, 2022 at 2:55 AM
DIVIDES
  • 903 POSTS
Replaced SAM, same issues if not more.
May 12, 2022 at 3:51 AM
DIVIDES
  • 903 POSTS
Also, even though it has the sane exact numbers, sometimes it will start others not, and when turning radio on it says anti-theft. Had lots of codes, reset it, disconnected battery and connected sane thing. Ugh, i may put the old one back and recheck fuses. The large red wire on bottom of this SAM u it is pain to remove and out back.
May 12, 2022 at 4:21 AM
DIVIDES
  • 903 POSTS
I also connected the battery wrong for a second it sparked and i knew it, so I immediately removed it.
May 12, 2022 at 4:32 AM
DIVIDES
  • 903 POSTS
I reinstalled the first one and got it to start again, no throttle response and some codes. I think when i crossed the battery i blew something off. All fuses are good in the SAM module. Are there fusible links anywhere else? Based on the code terminal 15 is faulty that is why most of the time it won't start now.
May 13, 2022 at 1:37 AM
DIVIDES
  • 903 POSTS
Also, can you tell me what function does the solid red thick wire at the corner has?
May 13, 2022 at 1:56 AM
DIVIDES
  • 903 POSTS
Found out there us a pool of water underneath the driver side carpet. I cleaned it all and unplugged each connector, some had water other corrosion, cleaned with brake cleaner and blew it with air for now since i don't have electric spray. Still no throttle but it started, windows worked, radio screen works but no audio, lights work, tilt doesn't, sunroof doesn't. Throttle only works if i floor it and rom would start to got it higher. Is there a way to find out which of these little boards here have to do with throttle, sound, tilt and sunroof?
May 13, 2022 at 10:37 AM
DIVIDES
  • 903 POSTS
Traction has been on from before and still is but i never saw this code. While parked engine revs on its own. Also, it's strange that the throttle just flies on its own without touching the pedal all the way up and i have to turn it off. The sunroof may have been the main issue. It stopped working maybe due to a bad motor or all these electrical issues started, and the sunroof was stuck open, and water got in. Common on these junk cars.
May 13, 2022 at 10:46 AM
  • 55,554 POSTS
Sorry, you have two questions going on at once, I think I found the issue with the water damage, was this car under water? If so, you will need to remove all the control modules and clean the correction from the connectors. Once that is done, clear all codes and rescan the car. Can you do a complete CAN scan? This video will show you how:
https://youtu.be/InIlnsjOVFA
May 16, 2022 at 3:01 AM
DIVIDES
  • 903 POSTS
No not under water, this is a common issue with these cars always leak there for some reason, everywhere else is dry. I will do a complete scan.
May 16, 2022 at 3:09 AM
DIVIDES
  • 903 POSTS
Attached.
May 16, 2022 at 6:38 AM
  • 55,554 POSTS
way too many codes, either major wiring or control module issue. Can you clear the codes and then just turn the key on without trying to start the engine and recheck the codes?
May 16, 2022 at 7:33 AM
DIVIDES
  • 903 POSTS
This is after deletion. Most have to do with pedal sensor i guess except the first. I am just trying to narrow it down. As soon as i started the motor after deleting them all the engine started revving on its own real high and i turned it off.
May 16, 2022 at 8:47 AM
DIVIDES
  • 903 POSTS
This is after i started it and turned it off.
May 16, 2022 at 8:51 AM
  • 55,554 POSTS
Yep, this shows a bunch of electrical problems. It looks like the wiring harness could be bad or one of the SAM modules is still having an issue. You might want to try and leave the battery disconnected overnight to see if that does anything.
May 17, 2022 at 2:50 AM
DIVIDES
  • 903 POSTS
Okay. All the wires look good, none are torn or showing corrosion, but I will get an electrical cleaner and spray them all and see.
May 17, 2022 at 2:51 AM
DIVIDES
  • 903 POSTS
Replaced the gas pedal and sprayed all wire connectors and breakers under the carpet with electric cleaner. Started with no check engine light or traction. Throttle now solved. Most codes are gone. Deleted most and most were gone. Seat, sunroof, power tilt and radio sound still inoperable. First pic was from SAM module, deleted them and they gone. I think the battery was low.
May 19, 2022 at 1:40 AM
DIVIDES
  • 903 POSTS
Can you send me the wiring diagram to the front SAM module? I need to find a way to connect this big red wire where it doesn't come loose as the connector was so difficult to remove it broke the plastic connector around it, so i can now connect it but an sure at any point it will come loose. I can't find the plastic connector sold alone so i will need to find a way or replace that wire, just need to know where it goes
May 19, 2022 at 2:21 AM
DIVIDES
  • 903 POSTS
Also, where the fiber optics equipment so i can try to bypass it using the bypass tool?
May 19, 2022 at 2:32 AM
  • 55,554 POSTS
Here are the front SAM module wiring diagrams and a guide to help you do some checking:
May 19, 2022 at 3:27 AM
DIVIDES
  • 903 POSTS
The roof motor replaced, and sunroof now works. Is there any way you can find out for me the location of the modules like the telephone module, radio module, amplifier so i can try to bypass them and see if one is causing the sound issue.
May 24, 2022 at 4:27 AM
  • 55,554 POSTS
Not that I know of.
May 27, 2022 at 7:10 AM
DIVIDES
  • 903 POSTS
Sound fixed. Underneath the passenger floor by firewall on bottom behind the metal plate is a connector, bypassed it and all is good now. Only thing left is the power driver seat and power tilt.
May 27, 2022 at 7:39 AM
DIVIDES
  • 903 POSTS
Fixed seat and tilt. Checked fuses 45, 50, and 62 which have to do with the seat on driver seat, 62 was not even there, inserted one and everything worked except the front back of the seat, checked power to the motor and it's there, tapped on the motor a bit and all Is good one. I just have to put it all back together now. Thanks
May 27, 2022 at 9:12 AM
  • 55,554 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
May 29, 2022 at 2:36 AM
