My vehicle listed above was driving fine, a little loud but okay, then it started knocking really bad as I was getting off the highway, pulled over, went home by rt6 instead of highway in case I needed to stop. I got home fine, but it was sputtering every time I excelled the gas, and the knocking was still bad! I looked under the hood next day in light and the pendulum mount was busted so that was the knocking and although I thought initially fuel injectors. I tried changing spark plugs 1st, and put fuel injector cleaner in the gas tank, after plugs changed it ran a little better, but still hesitated when excelling, take your foot off the gas and go again and it was getting better. I figured I will change the fuel injectors anyway so it's faster. I did that and noticed an oil leak, so I changed the intake manifold gasket, valve cover gaskets, and the oil cooler gasket. I also changed the battery about a week before this happened. Get it all back together start it up, and although it's still loud it sounded better plugged the obd2 back in and got cylinder 2 misfire again, multiple cylinder misfire, throttle position sensor to high, and the c1130 code. I am now at a loss, I don't know what else to do at this point please help! I don't know it I may have not plugged something in correctly, or what, but as far as I can see now there are no leaks, and it all looks sealed properly, I'm beginning to think that loud noise under the hood may be more than just a hole in the exhaust.
Jun 12, 2023 at 7:06 PM
