Several codes maybe a vacuum leak?
128,000 MILES • V8 • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Had several codes. Deleted them all and changed the low battery on the key fob. No issues with motor, no rough idle, no leaks. After i deleted all codes only 2 came back which are in last picture. Does that usually indicate a vacuum leak? Water reservoir was low half a gallon. But i don't see any leaks.
Nov 5, 2024 at 11:19 PM
  • 55,746 POSTS
I can't read the codes, can you write them in for us?
Nov 6, 2024 at 2:09 AM
BHAMDOC1973
  • 2,007 POSTS
P116
P157
P171
P0026
B11db
P2279
P174
Once deleted all, only thing that cane back are p171, 0174
Nov 6, 2024 at 3:05 AM
BHAMDOC1973
  • 2,007 POSTS
more issues developed with the car, so I will ask about it in another question.
Nov 7, 2024 at 4:33 AM
