I'll shorten it and reword it to basic. A temperature sensor in the exhaust pipe ahead of the metering valve measures the exhaust gas temperature. The injection mixture starts when at least 200°C is measured here.The sensor is located before the SCR catalytic.
So much for the detailed system explanation but the basic thing is that you need to check both the Throttle Position Sensor and the DEF system temperature sensor. Then all the basic connections at the plugs and the normal things you would go through. Melted wire from hitting the exhaust system and the like.
Hope this works
Sep 12, 2020 at 4:18 AM
