Setting Top Dead Center?
266,000 MILES • 5.3L • 4WD • AUTOMATIC
HD2424
  • 190 POSTS
When I set top dead center, I know the dots on cam and crank are aligned at 6 and 12 and number one piston is all the way up. My question is, when number 1 piston is up. Is supposed to be flush with top of block or supposed to be down about an 1/8 or so? Engine is 5.3.
Thanks
Oct 2, 2022 at 10:00 PM
  • 55,797 POSTS
Here are how the timing marks should line up in the images below and yes, the #1 piston should be at the top, not down at all.
Here is a video of the job being done as well:
https://youtu.be/mrp9YXPaYFg
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Oct 3, 2022 at 8:37 AM
HD2424
  • 190 POSTS
Thanks.
Oct 3, 2022 at 8:54 AM
HD2424
  • 190 POSTS
Thanks
  • 55,797 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Oct 4, 2022 at 6:51 AM
