set rear engine mount
100,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
YOSEF LEVY
  • 7 POSTS
Want to install rear engine mount.
Engine is up by jack.
Cannot install the mount because not enough room.
When jack up engine, the car is up as well.
Should I loosen the other mounts?
Could I damage the car/engine if I will increase the jack up?
link to the 4th underbelly mount:
https://drive.google.com/file/d/1aQgnpihvYa8GNGt7bkfawapTBZYVBFAH/view?usp=sharing
schema of whole engine
https://drive.google.com/file/d/1b5yCyFofnrGKjPkcuFd5pXpFHvogjFMr/view?usp=sharing
schema of right and left mount
https://drive.google.com/file/d/1AYGKejHEOVNLbpWvUakN65KE3kmNuAgx/view?usp=sharing
pic of rear mount (not installed yet)
https://drive.google.com/file/d/1b3xl2bYuXZ2XPvBUC_yGQXEbVita8FkP/view?usp=sharing
Rgds.
Nov 21, 2021 at 7:22 PM
That is correct. You will want to loosen the other mounts so that you can get some separation in order to gain access.
Here is a guide that will help with this in general:
https://www.2carpros.com/articles/replace-motor-mounts
However, you will not damage anything at all by loosening them. Just be very careful that you make sure you have them still with holding with at least a few threads so that you don't drop it on the ground or worse, on yourself.
Please let us know what other questions you have on this. Thanks
Nov 23, 2021 at 9:50 AM
