How to set and adjust ignition timing?
1998 NISSAN SENTRA
229,554 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
AZDANNO04
  • 375 POSTS
A lot of miles on vehicle. figured since I've done everything else to it needs to be adjusted.
Jan 12, 2021 at 3:51 AM
I am attaching the inspection process and info that you should need. So let's run through this and let us know if you need more info. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed. Thanks
Jan 13, 2021 at 8:56 AM
PETESA
how do I check the base timing on a 94 sentra 1.6 DOHC
Jan 14, 2021 at 1:02 AM (Merged)
  • 31,937 POSTS
To set the ignition timing follow the diagrams below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
