Servicing Schedule - Toyota Hiace 1RZ engine
1998 TOYOTA
121,200 MILES
YN1978
  • 16 POSTS
Please help me with servicing intervals for my Toyota Hiace van, 1998 model fitted with 1RZ engine. Such as; oil/filter change, fuel filter change, coolant change, air filter change, etc.
Apr 20, 2013 at 11:38 PM
HMAC300
  • 48,601 POSTS
a lot of this depends on how it is driven and where, if severe conditions, like gravel roads sand etc it shold be done more often but normally oil /filter changes 5,000 miles air fitler at least once a year, twice if severe conditions, same with fuel filter. coolant change if green coolant every two years, if orange every 5 yrs. If an automatic trans every 50,000 and fan belt and tensioner every 60,000 miles.
Apr 21, 2013 at 1:22 AM
NWACHUKWU.MCN
What is the right servicing engine oil for toyota hiace 1rz engine, how often can one change the fuel filter because the filter is hidden under the injector housing. Thirdly, can I use toyota t-iv transmission fluid when the dipstick specifies dexron II. dexron II is nowhere to be found. Thank you.
Jul 19, 2016 at 10:16 PM
HMAC300
  • 48,601 POSTS
preferred engine oil is SAE 5w30 which I marked on bottle for transmission fluid if it's an auto matic it's DExtron II or DextronIII or the Toyota fluid
Jul 20, 2016 at 5:11 AM
HMAC300
  • 48,601 POSTS
next time please give engine size not model and what type of vehicle as well as stick or automatic
Jul 20, 2016 at 5:12 AM
