Servicing Schedule For Nissan Caravan KA24DE engine
65,247 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
YN1978
  • 16 POSTS
Please help me with the servicing program of Nissan KA24DE engine. I want to know when to change the following;
- Oil and oil filter
- Air cleaner
- Fuel filter
- Automatic Transmission Fluid
- Drive belts
- Timing chain
And any other information I may require to maintain this engine. It has done 65247 miles (105000Km).
This vehicle will be used in heavy traffic and will be used for public transport for carrying 20 passengers.
Jan 31, 2014 at 5:20 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
the oil every 3000 to 5000 miles. check it once every week or two to make sure the level is ok. every three months if it comes first. its not set in stone but its a good idea. when you check your oil look to see if its dark. if its not then not to worry. change the air filter when you take it out and its visibly dirty, usually about 20000 to 30000 miles. fuel filter every 10000 miles or so. transmission at 75000 to 100000 miles. the timing belt at 60000 to 75000 miles. drive belts only when they've gotten visible cracks in the micro-v's on the inside of the belt. or if the flat side gets really shiny and begins to squeak
Feb 1, 2014 at 12:04 AM
