Service vehicle soon light came on
196,000 MILES • 3.4L • V6 • 4WD • AUTOMATIC
RAYMOND M. COMSTOCK
I reset doing the pump the gas three times. It stays off until I put it in reverse, then the high beam indicator flashes and the service light comes on. I also reset the oil change.
Dec 7, 2018 at 2:17 AM
Good afternoon,
The pedal three times is for the reset for oil change.
The yellow service engine light is for fault codes related to the engine.
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
Is the service engine light on? If it is, you need to go to a parts store and have it read for free. Then once we know the code we can narrow the area of failure.
Dec 7, 2018 at 2:28 AM
RAYMOND M. COMSTOCK
I did not ask about the service engine light. Service vehicle soon was the question. Found out it was a headlight out.
Dec 7, 2018 at 6:41 AM
"Service light comes on." Those were your words, not mine.
Did you have the code checked? There is a code for the body side of the car that needs to be identified.
Dec 7, 2018 at 6:44 AM
