Service traction control/Service stabilitrak on and off
2007 GMC YUKON
153,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
NICKAREND73
Service traction control on and off.
Service stabilitrak on and off.
Check engine light was on but disconnected the negative battery terminal and it’s off for now.
Light rough idle.
I have cleaned the throttle body. What else could this be?
Oct 20, 2019 at 8:21 AM
Did we ever check for codes? The rough idle could be due to needing to relearn the throttle but lets start with codes.
The stability track light would not be related to the rough idle but could be a number of different items which is why we need the codes. Just make sure the code reader is able to communicate with the ABS module or it may tell you there are no codes but if these lights are on then there should be codes. Thanks
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Oct 21, 2019 at 7:36 AM
