Service stability warning comes on for the autoride system
120,456 MILES • 5.3L • V8 • 2WD • AUTOMATIC
JCHAO
This causes the rear brakes to close as if the parking brake was engaged their is an override button to bypass stability control that only worked once I have disconnected the battery to reset it did help but problem returned. I have checked all fuses they check out ok, I was told to replace the ALC automatic leveling control relay but I just cannot seem to locate in the engine compartment I looked for it in the fuse box in the engine compartment no luck, I also checked for air leaks I cannot hear any air escaping from air lines leading to air shocks
Jorge
Sep 15, 2014 at 8:27 AM
HMAC300
  • 48,601 POSTS
scan for codes first a pro has to do it.
Sep 15, 2014 at 11:05 PM
