Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Yukon
Suspension
Sway Bar
Replace/Remove
Service stability
2004 GMC YUKON
173,000 MILES • 4WD
LIBO
MEMBER
1 POST
I am replacing the wheel bearing column and now shows the light service stability on.
Jan 24, 2018 at 8:33 PM
Experienced Mechanic
It sounds like you have a defective wheel bearing hub or you forgot to plug the ABS wheel sensor in. Can you please double check for me?
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Jan 26, 2018 at 2:33 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
