I would have the codes checked at a parts store. Once I know the codes, I can further help you. This service for pulling the codes is free.
Apr 5, 2020 at 3:10 AM
LATOYABURNS50
MEMBER
So if my service light is not flashing i can still drive? Still confused about what the service light means.
Apr 5, 2020 at 3:27 AM
✓Experienced Mechanic
That is correct. The service engine light indicates a fault in the engine control system. A codes is stored in the system for the area of the failure. That is why I need the code that is set. Then I can help narrow the area of failure.
