SERVICE INDICATOR
120,000 MILES • 6 CYL • RWD • AUTOMATIC
TASHA THOMAS
I went on YouTube to reset service indicator, I have already had the service done. I believe I reset the oil indicator in error. Now the car will not start. It tries to start but does not turn all the way over. I know there is menu fix with reset button I forgot how.
Nov 16, 2016 at 11:09 PM
JIS001
  • 3,412 POSTS
Check your battery first. You could have ran it down when the key was on and if you had the blower motor and radio running. Trying to reset that without the scanner I have spent up to thirty minutes trying to navigate through the cluster.
Nov 17, 2016 at 2:32 AM
