Service Engine Soon light with P0135 code on 2003 Pontiac Montanan
64,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
XJSHEN
  • 251 POSTS
After get battery replacement service in GM dealer, I got 'Service Engine Soon' light on dash board with code p0135 on my montana. Before that my car have not had any problem.
Once clear the code p0135 and removed Service Engine Soon light, but after runabout 17 mile the Service Engine Soon light comes up again.
If anyone have good idea on the problem? What could be problem and How to fix it?
Thanks any comment and help! except following comment:
xjs
There are so many possible causes I can not figure them out.
Apr 8, 2014 at 1:43 AM
JDL
  • 16,098 POSTS
Did you troubleshoot the code? Did you do any repair? 02 heater circuit, bank 1 sensor 1.
Apr 8, 2014 at 2:15 AM
XJSHEN
  • 251 POSTS
No. I only cleared code. But service engine soon light comes again after about 17 mile run.
Apr 8, 2014 at 2:52 AM
JDL
  • 16,098 POSTS
Oxygen sensor, bank 1 sensor 1, heater circuit, according to the code #, the oxygen sensor is in the exhaust.
Oxygen sensor is part of a tune-up. Could be faulty sensor, could be issue with wiring circuit?
Apr 8, 2014 at 3:43 AM
JDL
  • 16,098 POSTS
The code will return if you didn't fix the problem.
Apr 8, 2014 at 3:45 AM
XJSHEN
  • 251 POSTS
Thanks!
GM shop replaced with new part free after I purchased from Advancer Autoparts $27.
Thanks GM shop! It is reasonable service.
Steven
Mar 12, 2015 at 9:43 AM
JDL
  • 16,098 POSTS
Hey, glad you got it fixed.
Mar 13, 2015 at 2:24 AM
