I had the light for the last couple hundred miles and was running ok with it as I did not have a chance to work on it. Today made a 15-mile trip and the engine started missing. Then the service engine soon light stated flashing then went solid for a few minutes and started flashing again. The truck felt like it was losing power on and off. Would idle ok but when you started to accelerate would miss. Made it home barely. Did check code before and it said purge solenoid check valve which I could not find. Hope the engine is alright and can be fixed.
Jul 10, 2024 at 7:01 AM
