Service engine soon
38,000 MILES • 1.0L • 2WD • AUTOMATIC
HARVEYP
Only comes on when vehicle makes sharp left turn.
Nov 10, 2017 at 2:40 AM
WRENCHTECH
  • 20,760 POSTS
The "check engine" or SES light is an indicator for a system that monitors many electronic functions in the system, also called the "malfunction indicator lamp" (MIL). It can come on for any of hundreds of different causes from any of the systems that the computer monitors. Some are very important and can lead to further component or engine damage and some are emissions related not as serious but still a problem and need to be repaired.
Your first step is to have the computer scanned to retrieve the trouble codes that were set when the check engine light came on. Those codes will give you specific information about what the computer saw and will get you pointed in the right direction to find your problem. With a 1996 or newer and some 1995 cars and you have an AutoZone or Advanced auto parts in your area, they will read them for free. Once you have these code numbers, we can be a lot more specific about what your problem may be.
Nov 10, 2017 at 7:32 AM
HARVEYP
Thanks, I will follow up with the codes.
Nov 10, 2017 at 7:55 AM
