Service engine light soon, code P0455
144,000 MILES • 4.2L • V6 • 4WD • AUTOMATIC
BLESS2SUCCESS
  • 45 POSTS
My service engine light won't stay off after I had change the fuel cap, purge valve and charcoal canister valve. What other problems can be done to finally repair this issue?
Jan 12, 2019 at 1:34 AM
KENW1
  • 213 POSTS
Thanks for visiting 2CarPros.
The next steps would be smoke testing the evap system to see if a line is cracked or leaking at a seal.
If no leak is present it may be the fuel tank pressure sensor.
https://www.amazon.com/ACDelco-16238399-Original-Equipment-Pressure/dp/B000NW4OPC
Jan 12, 2019 at 3:23 AM
