Service engine light on and off
2008 KIA OPTIMA
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHN ANTHONY2
Hi, my friend's daughter has the car listed above and at times the engine light will go on. A friend took the code and it states something like transmission module. The engine light comes on and off at different times. What can correct this issue? Thanks in advance.
Jan 1, 2018 at 12:50 AM
Good morning.
We need the code number to narrow the area of failure so we can give you some ideas on the issue.
Can you ask him for the exact code number?
Jan 1, 2018 at 1:11 AM
JOHN ANTHONY2
Hi, I guess there were two codes. The are P0741 and P0700.
Thanks,
John
Jan 1, 2018 at 2:31 AM
Okay, these are both transmission codes. Let me get the information for you.
Jan 1, 2018 at 2:33 AM
OKay.
The 700 is a general transmission fault code. The 741 is the fault code.
Below is the description for the code. It is for the torque converter. In most cases, it ends up as a transmission replacement. You can read the description. It will need to be verified by someone before assuming anything.
General description:
The PCM/TCM controls the locking and unlocking of the Torque Converter Clutch ( or Damper Clutch ), to the input shaft of the transmission, by appling hydraulic pressure. The main purpose of T/C clutch control is to save fuel by decreasing the hydraulic load inside the T/C. The PCM/TCM outputs duty pulses to control the Damper Clutch Control Solenoid Valve( DCCSV ) and hydraulic pressure is applied to the DC according to the DCC duty ratio value. When the duty ratio is high, high pressure is applied and the Damper Clutch is locked. The normal operating range of the Damper Clutch Control duty ratio value is from 30%(unlocked) to 85%(locked).
DTC description:
The PCM/TCM increases the duty ratio to engage the Damper Clutch by monitoring slip rpms (difference vlaue beteween engine speed and turbine speed ). To decrease the slip of the Damper Clutch, the PCM/TCM increases the duty ratio by appling more hyraulic pressure. When slip rpm is not drop under some value with 100% duty ratio, the PCM/TCM determines that the Torque Converter Clutch is stuck OFF and sets this code.
DTC detecting condition:
Monitor scan tool data:
1. Connect scantool to data link connector(DLC).
2. Engine "ON".
3. Select "D RANGE" and drive vehicle.
4. Monitor the "TORQUE CONVERTER(DAMPER) CLUTCH" parameter on the scantool.
Specification : TCC SLIP40% )
imageZoom/Print
5. Are "TCC SOLENOID DUTY and TCC SLIP" within specifications?
YES
> Fault is intermittent caused by poor contact in the sensor's and/or TCM(PCM)'s connector or was repaired and TCM(PCM) memory was not cleared. Thoroughly check connectors for looseness, poor connection, bending, corrosion, contamination, deterioration or damage. Repair or replace as necessary and go to "Verification of vehicle repair" procedure.
NO
> Go to "Component inspection" procedure.
COMPONENT INSPECTION
1. CHECK TORQUE CONVERTER CLUTCH SOLENOID VALVE
(1)Connect scantool to data link connector(DLC).
(2)Ignition "ON" & Engine "OFF".
(3)Select A/T Solenoid valve Actuator test and Operate Actuator test.
(4)Can you hear operating sound for using TCC SOLENOID VALVE Actuator Testing Function?
YES
> Go to "CHECK OIL PRESSURE" as below.
NO
> Replace "TCC SOLENOID VALVE" as necessary and Go to "Verification of Vehicle Repair" procedure.
2. CHECK OIL PRESSURE
imageZoom/Print
(1)Connect oil pressure gauge to "DA" ports.
(2)Engine "ON".
(3)After connecting Scantool and monitor the "TCC SOLENIOD VALVE DUTY" parameter on the scantool data list.
(4)Operate vehicle with 3rd or 4th gear and operate the "TCC SOLENIOD VALVE DUTY" more than 85%.
(5)Is oil pressure value within specification?
YES
> Repair TORQUE CONVERTER CLUTCH(REPLACE Torque Converter ) as necessary and Go to "Verification of Vehicle Repair " procedure.
NO
> Replace A/T assembly (possible to BODY CONTROL VALVE faulty) as necessary and Go to "Verification of Vehicle Repair " procedure.
VERIFICATION OF VEHICLE REPAIR
After a repair, it is essential to verify that the fault has been corrected.
1. Connect scantool and select "Diagnostic Trouble Codes(DTCs)" mode.
2. Using a scantool, Clear DTC.
3. Operate the vehicle within DTC Enable conditions in General information.
4. Are any DTCs present ?
YES
> Go to the applicable troubleshooting procedure.
NO
> System performing to specification at this time.
Jan 1, 2018 at 2:37 AM
JOHN ANTHONY2
Thank you for the quick response Roy. I will pass the information on.
John
Jan 1, 2018 at 2:41 AM
You are welcome.
Jan 1, 2018 at 2:48 AM
