2006 Kia Optima check engine light
90,000 MILES • 6 CYL • 2WD • MANUAL
ARROWAMW
had it tested code came back bbevap emission canister clogged probable cause blocked evap canister clogged is the air filter?
Mar 29, 2009 at 5:13 AM
  • 110,251 POSTS
I'm not sure I understand your question. The evap canister has nothing to do with the air filter. I believe it is located near the fuel tank on your year vehicle. Make sure there are no damaged hoses going to it from the fuel tank.
Jul 11, 2009 at 1:33 PM
