Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Lesabre
Warning Lights
Check Engine Light
Service engine light flashing, engine is losing pressure, vibrating, and misfiring
2001 BUICK LESABRE
100,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
HOPE FULLER
MEMBER
1 POST
Changed plugs and coil pack and it is still running sluggishly.
Dec 16, 2021 at 10:50 PM
Experienced Mechanic
Good morning,
I would start by checking the compression in the motor to be sure there is no issue internally. You need 140-160 pounds in each cylinder.
Then I would check the fuel pressure to be sure there is sufficient fuel in the injectors.
Check for the spark to all the cylinders as well.
Let me know the results and when we have it narrowed down, we can pinpoint the failure.
Dec 16, 2021 at 11:35 PM
Add image or video
Ask a new question
Engine stalls while driving
Engine won't start
