Service engine light
137 MILES • 5.7L • V8 • 2WD • AUTOMATIC
HJEROMESMITH
How do I find, diagnose and clear message?
Apr 2, 2019 at 12:05 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Your vehicle has an OBD1 computer system. You need to retrieve diagnostic trouble codes from it and it is very easy. All you will need is a jumper wire about three inches long or even a paper clip.
Go to this link. It describes how to retrieve codes for your vehicle. Additionally, it lists what each code means. Once you do that, let me know what code or codes you found, the present concerns, and I will help you diagnose the issue.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let me know if this helps and what you find.
Apr 2, 2019 at 12:53 PM
